Anti virus software for mobile phone
I have recently purchased a Galaxy Grand and HTC Butterfly but Both having corrupted by one virus, I am looking For some good anti virus software for mobile phones kindly suggest.
Hello Stoll,
AVG Antivirus for Android Smartphone.
Features:
Features:
Features:
Features:
To download, check the link.
Hope this would help you.
Thank you.
1. AVG is a high quality solution for guarding Smartphones viruses and to top it all up there are available free versions.
AVG also provides tools to optimize the device and a tool for anti-theft protection.
2. The McAfee anti – virus will also be able to neutralize most viruses. It also provides tools for Anti theft and also a tool for SMS and call filtering.
Hi Stoll,
One of the best antivirus for your Smartphone is Avast. It is completely secure and avoids theft of your phone. It is possible to browse without any worry by using Avast antivirus software. Moreover, it is possible for you to see your security status all the time by using this software. Another one which can be used is AVG. It is an advanced security system for your phone.
