Antivir premium 9 re enables a Disabled Job
Hey guys,
I have a problem with the Scheduler in AntiVir Premium 9.I have a weekly scan that I implement. But this week I did not want to run it so I unchecked it as an option. But when the time came for the scan to run it actually ran even though I unchecked it. When I check it has been rechecked as an option. How do I fix this?
Answered By 5 points N/A #176649
Randolph Hello Arthur
I know AntiVir premium has such a problem. It sometimes re-enables itself a disabled job. What you must do, is delete the weekly scan that you created, restart the software, and create another one. If this does not fix the problem, the solution is to uninstall the software, and re-install it.
You can download it from Here I hope you found this information useful.
www.avira.com/en/download/product/avira-antivirus-premium
Randolph
