Antivirus gets disabled automatically while playing game
Today I ran into the problem where running Blackshot game causes my Antivirus to crash, hence disabling it. I tried re-enabling the Antivirus, but it crashes again. This continued until I closed Blackshot. This incident has never happened before, and I was away from the game for only a week. I've tried adding both Garena and the entire Blackshot folder into my Exclusion list, but the problem still persists. Disabling the Antivirus allowed me back into Blackshot, but I feel that this is a security concern.
Best Answer by JagsH
Answered By 0 points N/A #128027
My friend, in your post you did not mention the Antivirus and the OS you are using.
Some Antivirus has the option known as the “Gaming Mode” and as I can anticipate after reading your post, the gaming mode is most likely being launched automatically and not working in an appropriate manner.
You could look into the various options of your Antivirus program and changing them. You can also try solving this by making sure that your antivirus has all the latest updates.
If your antivirus program keeps playing up, you can try uninstalling and then reinstalling or changing to a different Antivirus program. These days there are many Antivirus solutions that offer comprehensive but absolutely free services for home users.
Try this link if you want to browse a little more.
Cheers!
Answered By 0 points N/A #128030
There is one reason why this could happen.It is might be because your Antivirus software is crashing and it is most likely due to it detecting Blackshot as a virus/trojans. After it has detected it, the Antivirus would notify you in a window.The Antivirus software seems to crash when it tries to bring up the notification window. To clear your doubt, Blackshot does not contain any harmful virus/trojans. It is a false alarm by your Antivirus software. Try to reinstall your Antivirus software.
