Antivirus personal error during the install of plug-ins
Hi there,
I have a problem with antivirus personal. Plug-in works just fine with Nu2Menu but with BS Explorer it gives an error. Exactly the same error when I choose what drive to scan with MacAfee scanner with GUI. Can anyone help me please to fix this problem ?
Thanks !
Antivir personalEdition Classic
B:Documents and SettingsDefault UserDesktop refers to a location that is unavailable. It could be on a hard drive on this computer, or on a network. Check to make sure that the disk is properly inserted, or that you are connection to the Internet or your network and then try again. If it still cannot be located, the information might have been moved to a different location.
Answered By 590495 points N/A #178176
I think the problem is because you are using more than one antivirus on your computer and it will really cause a problem especially in the file access. You received this error maybe because the other antivirus is currently accessing the folder. To fix the problem, choose only one antivirus to run on your machine. This will not only improve the performance of your computer but will also fix the error.
Select between your AntiVir and McAfee antivirus programs which one to uninstall and which one to retain. In general, a computer should only be running one antivirus application on the system for its security. Running two different antivirus programs will cause file permissions error when you access a file or a folder with another application.
