Antivirus Software Usage and Why
Hello Jnd1225,
I can tell you one of the best is Eset Nod32. Why? Because when I was working in a computer company most of their computers used it and the main thing is it’s easy to use and up to date.
Being the best antivirus is it has a script which blocks those scripted antivirus that are knowingly created from minor virus. You can easily manipulate while scanning your computer, files and options for scanning either you automatically delete the threats files or not. It has a less memory not like other antivirus makes your computer working slower. Being the best antivirus even a non virus like .exe file which is created from a script will automatically delete that's how Eset one of the best . Unknown files that being scanned equals delete.
Hope I did even refresh your mind to think,
Rabin
In order to protect the important files in your computer you need to use some tools that will block different security threats. Because files are very raw, in the form of an electronic or computer code which can easily be modify, damage and worse delete. Files’ great threat are viruses which, if infected, may alter its contents because the virus attached itself to it and would eventually lead to more severe infections if the infected file was launched.
If you are looking for the best antivirus solution that will protect your computer from harmful malwares, here are some of the best brands:
Download any of these programs using your web browser like Microsoft Internet Explorer or Mozilla Firefox. Just click on the link and start browsing their pages.
