Antivirus : Virus hides windows files
I am in big trouble. I am using avast antivirus and virus hides windows files. I think the antivirus is not working properly or not able to remove the virus. Please suggest me some good antivirus for resolving this issues.
Best Regards
Best Answer by Trotsky Timothy
Answered By 0 points N/A #141234
Hi Oliviarwilkes,
Just update your antivirus software, and then run scan. And if didn’t work, if you have idea which file is causing the problem just send the file name to avast customer support. If you really want to change your antivirus you may choose the most credible one that is Norton antivirus/Norton internet security or kaspersky.
Answered By 50 points N/A #141236
Download malwarebytes antimalware from malwarebytes.org. Much better in scanning and removing virus from your PC than any other antivirus software.
Good Luck!
Answered By 10 points N/A #141235
If you are facing problem with virus in your PC then at first you can uninstall your antivirus and then install the antivirus again. After that start the scan and then if the problem is solved then it is OK but after then if you face problem then you can change your antivirus. I think that will help. Try this.
