Anvi Folder Lock- A Security Tool
I have some folders on my laptop which needs to be protected from unauthorized access whether it is my family members. How can I ensure the safety of the data stored in that folder?
You can use free software named Anvi Folder Locker which will help you lock your folder containing some private, sensitive data. You can use it by downloading it from the Internet, and then installing it. When you open it, you have to set a master password, which is case-sensitive. You can also your email id to recover your password. Then you have to select the folder and lock it with your master password or a different password. Now the data in your folder is locked.
