waleed107
10 points
Posted on - 10/28/2012
I came across with a tool known as MULTIDIG, they call it DNS MAS Query Tool.
It performs a "dig-like" resolution on each server in a list.
The problem is that its not returning the DNS entries which have redirect set on them.
Do you people know any other tool like that.
I want to use such tools for my project.
Any Alternative For DNS Mas Query Tool
Hello Waleed,
You could forget about searching for other tools and look into the problem caused by multidig and to fix it.
But if you are looking for other DNS MAS query tool, the links below should be of help to you:
Passive DNS query tool
The DNS Query tool
I hope I've pointed you in the correct direction and I hope you find what you are looking for.
