I bought my 14 year old daughter an iPhone and she was using it in the right manner at first. Recently, I notice that she has been texting frequently even during class time and she also makes a couple of calls. I have talked to her but she wont change and whenever I take back the iPhone she gets depressed and my partner tells me to return it. Now I want an app that would monitor every activity she does with the Phone so that I can try and help her stop the behavior. Any ideas?
Any apps to monitor children phone usage?
Many parents facing same problem that you mentioned. It is possible to have a track on what is your children doing using the “PhoneSheriff” software. This software is very useful. When you install PhoneSheriff onto the iPhone, it logs the user’s activities. These activities information can be send to your private account so you can access it online from anywhere. It also allow you settings in order to restrict the way of using the iPhone.
You can set filters and restrictions such as:
1. Application Filter
2. Website Filter
3. Time Restrictions
4. Block calls and texts
5. Geo fencing alert
You can monitor activities like:
1. Phone call information
2. Text messages and iMessages
3. Website history and notes
4. Instant GPS locations
5. Photos taken
It is undeniably we are obsessed with technologies!
If you’re a parent and looking for parental control app for IPhone, this is exactly what you need! It doesn’t matter if you’re old or young, this is the perfect solution on your question.
This is designed for IOS users. We call it “MOMENT”. This software that you can download for free will track you or any person on how they use their smart phones. It will show or indicate how long you have been using it and when you need to turn it away or to take a rest from using your phone. We can set up alarms or reminders like what any other monitoring apps can offer. It can also show your exact location and limit your time the usage of your phone in that location. Meaning to say we can limit on how long we can use it inside your bedroom or in any place.
There are other software for free that you can download. There are other apps that you can download that doesn’t work and crashes while launching it. There is another app called Mobile Watch Dog. You can just download it in apple store and it will take a few minutes.
