Hello, my friend insists that there is a benefit to an actual wired mouse versus a wireless mouse, but I can't seem to figure out any real benefit. I use a wireless mouse all the time and do not have issues. Is there anything that I am not realizing with a wired mouse that would be of benefit?
Any benefit to a wired mouse versus wireless?
Hi, Thomas T Deloach Cable mouse vs. wireless mouse cable mouse is more lighter and agile compare to wireless, less the reason for this is very simple. Wireless mouse is heavy and it builds a lot pressure in your hand while using it and later on it create pressure in your hand and you will easily get tired. the only advantage on the wireless is you don't have the worry of wires that will get in your way sometimes.
