Any body can help about Microsoft windows 10
Hello, What is the resolution standard in Microsoft windows 10? Is 1gb ram enough for Microsoft windows 10? Which processor is needed for windows 10? Can windows 10 display on my 17 inch screen? Can it be run on any device like phone, tab? Is there any new application?
Thank You
Answered By 0 points N/A #189087
Hello !
Here are the System Requirements for Windows 10
1.  Processor: 1 gigahertz (GHz) or faster
2.  RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
3.  Free hard disk space: 16 GB
4.  Graphics card: Microsoft DirectX 9 – 11 graphics device with WDDM driver
5.  A Microsoft account and Internet access
A 17 inches monitor’s maximum resolution capacity is 1280 x 1024. Windows 10 only requires 800 x 600 resolution in monitor or screen. Yes you can use it with your monitor. The new features for Windows 10 is that it is a touch – screen enabled platform, command prompt have keyboard shortcut, you can snap with your windows, and the universal applications design that floats in your screen.
Cortana is your personal assistant in windows 10, can search information in website or internet, can organize your calendar and notify you with your daily appointed tasks.
