Any code for java window ad tool please
Hi everybody,
Could you provide codes of authentic for Java Windows Active Directory tool please,welcome experts.
Thank you.
Hi everybody,
Thank you.
You can authenticate the AD through Java by using types of authenticating procedures. These are Kerberos, NTLM and LDAP. LDAP is widely usable for basically validating a username along with a password. You will find the test codes in many websites.
For LDAP procedure-
For JNDI process-
You can successfully perform an Active Directory Authentication by using JNDI, this is a newly launched program that can show how to authenticate such as windows active directory.
The advanced platform makes it easier for us to fully utilize its functionality. Provided with this solution is the link where you can access or view the progress done by using this Windows Active Directory Authentication.
http://blogs.artinsoft.net/Mrojas/archive/2007/05/14/Active-Directory-LDAP-and-Java.aspx
