Is any domain names registered today?
How can we get the list of all domain name registered today and how to locate the records of the domain names?
Hello Anshio,
You can get the list of all domain names registered today by simply downloading and using a simple software called Domain Seeker. It is a free software package by Springboard web services. The software will enable you to search all existing domain name whether .com, .net, .info and so on. You can go to http://www.makeuseof.com/tag/search-uncover-domain-names-domainseeker/ and get a look at the description and how to use the software.
To locate the records of the domain names such as where the domain name is hosted from (country), you can simply use the following URL and I hope it will really help you. http://www.whois.sc/
Thank you.
Notifications
