Any emulator for mame for wm 61?
I just purchased a new Touch Pro today. I have installed some old arcade games from my Windows Mobile, do you know any emulator for mame for wm61?
Hello Aron,
You can try the Nester Plus emulator and see if it will run. It is meant to be used on the Touch Pro. For the emulator to work, you will need to download roms and then paste it to subfolder roms. After pasting the roms in folder roms, they will be visible in emulator PCMAME (pcmame.exe).
Carl
Dear Aron Morgan,
MAME works on Omnia. Download pcmame04a and install it on your Omnia phone. Then, download Roms (games for MAME) and paste it to a subfolder called roms. (The main folder is pcmame04a.)
After pasting the Roms into the folder roms, they are now visible in the emulator PCMAME (pcmame.exe). I had some trouble to redefining buttons, but after spending a lot of time, I succeeded.
Best regard,
Don Muench
