Any flash for television lg upgrade firmware?
Hello experts!
Guys do you know site where I can download flash for television LG upgrade firmware? I researched that it is possible to upgrade my LG televisions by myself. Although this is a risky one I just want to give it a try. Does anyone know where I can get the upgrade firmware available for series of my LG. I can give a series and product serial for genuinely purposes.
Best Answer by Edmund Joseph
Answered By 0 points N/A #152671
Hi Alison Maybou,
You want to download the upgrade firmware/flash for LG Television, Then you can download the upgrade of any proper model from the official site of LG.
http://www.lg.com/uk/support
Here you will find the manual and upgrade of proper model.
It may helps you. Thanks!
Answered By 5 points N/A #152672
Hi there user:
Connect your PC to your TV, there’s one (1) device that can transmit HDMI wireless from your PC to TV. (VGA and AUDIO Cable 3.5 mm) Purchase it. A bunch say that the application on TV were nice, but not so practical. Risky, cause if you made a mistake, the price to get it repaired will be a headache. Just connect your TV onto your PC and that’s it.
Thank you for dropping via techyv.com. Keep on posting your queries.
