Hi all,
Is there any good freeware for creating Html greeting card program using which i can create greeting card for my loved ones and express my feelings for them?I am seeking such a greeting card software that provides plenty of variety in text,clip art,photo editing tools,layouts and many more.
Any good Html greeting card program?
Hi Jeffrey,
Yes you can get card from many ways like from greeting card websites and if you want to write your own card so you can write script in HTML and if you have copied any card so right click on that card go to view source and edit the HTML coding It is easiest method for edit any card you like.
. Hopefully this information will help you.
Thanks,
Raun Nelson
Hi Jeffrey,
Yes you can get cards from many ways like from greeting card websites and if you want to write your own card so you can write scripts in HTML and if you have copied any card so right click on that card go to view source and edit the HTML coding It is the easiest method for edit any card you like. Hopefully this information will help you.Â
Thanks,
Raun Nelson
