Any good language dll converter for movies from Iphone to PC
Asked By 85 points N/A Posted on -
Hello techyv.com!
I have a movie from my iPhone that I want to watch on my PC, but when I transfer the data from the iPhone, it says "cannot find dll convert",
I was thinking if there is a language dell to convert that could convert my iPhone movie so that I can watch it on PC?
Thanks techyv.com!
Best Answer by Peter A May
Answered By 10 points N/A #170299
Hello Luke,
Actually, you don't need to use any converter to convert videos from iPhone.
Just install a good video player on your PC that supports all file formats.
And just play video or audio files you want to play.
There are many video players available for free.
Download video player here
You can download converter as well.
Download free video converter here
Hope this solves your problems.
Thanks,
Answered By 10 points N/A #170298
Hi Luke N Marks,
Cannot find dll convert" is a common error. This error occurs for many reasons but the best solution is installed that missing or corrupted file. Here I am giving you that missing file but before download just check your registry settings.
After registry setting if it persists then download this file Download link
Here the system what you should do-
After download file you should open that and “Extract all” and extract to C and try to understand this picture-
1. Then press “Ctrl + r” and type here cmd
2. You must see a black page
3. And type here  regsvr32 converter.dll for installing
4. Press on “Enter”.
5. If you want to uninstall just type here regsvr32 -u converter.dll
Best of luck
