Software that can detect corrupted files
Hi! I need some help. Is there any software available which detects itself that there is a file in computer which is not working properly. And that software itself heal that file. It should also delete the unwanted files from the computer to maintain the computer speed. If you have any idea please let me know. And also attach link of that software. thanks.
Best Answer by ayegired
Answered By 5 points N/A #86009
to find the corrupted files automatically and to heal them use avast antivirus and to see the system errors use registry booster.it can increase the system performance by removing the unwanted files in the system.
so install
1) Avast antivirus
2) Registry booster
Thanks,
Anilkumar.
Answered By 0 points N/A #86010
Key Features
  • Automatically finds and fixes common problems
  • Accelerates startups
  • Defragments disk for faster performance
  • Frees up disk space – boosts performance
  • Removes cookies, temporary files, Internet clutter
  • Lets you view current Windows processes for maximum performance
  • Purges unwanted security-sensitive data
  • Automatically benchmarks performance to optimum standards
  • urge sensitive files – Permanently deletes unwanted sensitive information from your PC so intruders
  • cannot access your data
link: https://www.avast.com/en-in/free-antivirus-download
