Any idea about mmosrpg Mac flash based
Hi everybody, Do you think if choosing mmosrpg mac flash based, i should boot windows for that?
Thank you in advance
Hi
You can install Windows on a separate partition of your hard drive by using Boot Camp; this way you will achieve the best performance, but you won't be able to switch between OSX and Windows without restarting your Mac. The other group of solutions is to use virtualization platforms, such as "VirtualBox", "VMWare Fusion" or "Parallels Desktop".
1. VirtualBox is the most difficult to setup, so if you don't have the patience or the technical knowledge, rather pick another option.
2. Parallels Desktop is better at gaming, because it supports DirectX much more fluidly and up to 1 GB of video RAM, as opposed to Fusion's 256 MB.
3. Fusion has a much greater library of applications it is compatible with, including other operating systems.
