Abram Jock
80 points
Posted on - 09/17/2012
Is there any ICQ to Trillian history converter? I do not wish to keep ICQ installed, but I need to review its old files often for my work, so I would like to move it all to Trillian, if there is any suggestion?
Any ISQ to trillian history converter please
Hi Jock,
Your problem is solved there is ICQ to Trillian converter with all the features you want it will help you to convert, many websites having this software with detail description and user manual guide I also had visited many websites and after surfing and discussion with many experts now be happy and download from any website just open Google and type ICQ to Trillian converter you will get a number of sites which offer you to download free just download and use it according to your requirement.
Lecky cruz
