Any MS Access 2007 Hindi Tutorial Sites?
Good day to all of you!
My friend has a brand new computer and have an installed MS Office. Also, he has recently been studying Hindi Language. Now he asks me if I have any tutorials of MS Access in Hindi language. But I don’t have one. So computer geeks, does anyone of you know any MS Access 2007 Hindi tutorial sites on the web? Any help would be nice. Thank you and a pleasant day to all of you.
Hink Lerbert
Answered By 0 points N/A #170283
Hi Hink,
what I am about to provide you is not exactly a Hindi Tutorial but your friend would be able to view menus, dialogs and other interface of MS Access in Hindi Language. You can ask your friend to go to Microsoft download center, the link will have a list of different Language Interface Packs (LIP), its Native Name, the required base language (which you need to have for the new language to work) and the download link. He just needs to click on the download link for the Hindi LIP then he will be redirected to another site. Look for the download links for the .mlc files and select if its 32bit or 64bit depending on his computer. When he clicks on the link, he can choose to save it on his computer or open it directly. If he chooses to save it on his computer, he will need to double click on the saved file to install the language pack once the download finishes.
Please note that the link above is for Windows XP, below are the links to other versions of Windows:
Windows 7: https://support.microsoft.com/en-us/help/14236/language-packs
Windows 8: https://support.microsoft.com/en-us/help/14236/language-packs
Windows Vista: https://support.microsoft.com/en-us/help/14236/language-packs
I hope this helps.
Laurie
