Any network management software for home network ??
Can you give me any suggestion? I have 3 computers in home network and I want a network management software for home network so that I can manage it remotely.
Hi Simon,
In order to manage the computers connected in a home network, the best network management and monitoring software is Network Magic Pro.Â
It can make your network management and monitoring tasks simple and easy by creating a dynamic interactive map allowing you to view each network and also shows the status of connected devices. It also,
The only back draw for this software is individual access to users for specific devices, other than that it is a perfect network management and monitoring software and is highly recommended for a home network.
Hope that helps.
There are thousands of free softwares to manage your home network, but here are the ones I personally use and would recommend:
Xenoss
Vollectd (this is a great manager but a bit difficult to use)
Cacti
Nagios
Monit (this one is easy and great)
I hope this helps. If you don't like any of these, feel free to ask and I will suggest more. Thanks and have a great day.
