Any one can tell me what template is used at below site.
Hellow ShaheenIqbal20,
I have reviewed your given site .This is a customized website using ZenCart template.
Details of this template:
Software Required:
Image processing :Adobe Photoshop CS 4+,Corel Draw;
Web Development:PHP 5.2.14 or higher;
Database Design: MySQL 4.1.3 or higher;
Apache 2.0 or higher;
PHP configured to support CURL with OpenSSL;Zen Cart 1.5.x
Features: Admin Panel
Animation: HTML Plus JS
Functionality: Online Store/shop
Layout: 3 Columns
Width: 1920px
You can see the Live Demo here: https://www.templatemonster.com/demo/42335.html
You can use free trial version of this template:http://www.templatemonster.com/free-zencart-1-5-template.html
You can contact with an expert web Developer to get more support for building such a site by sending email to [email protected]
I hope this will be helpful
Shifflett Laurel
Hi Shaheen,
Flipkart.com is one of the major E-commerce website originating in India which is built on the platform PHP language,
MySQL as database engine and Apache as its server.
The template used in the website is created with the help of Zen Cart and Joomla CMS.
You can also use Joomla to create an end product like Flipkart.com.
To know more about Joomla please visit the following link.
Thanks
Baker
The template may be ZenCart template. By using Joomla this type of eCommerce site can be created.
The ZenCart templating system uses a CSS based layout.
It uses CUSTOM for your template and ENGLISH for your language by default.
Change these if needed.
If you want to build up this kind of template Please check here.
Hope it will help you.
Regards
Franke Mary
