Is any remediation available for Docker’s older version?
It is found that the Docker engine upto 1.3.1 version (including it) is vulnerable with flaws. It is said that it can lead to extracting files to paths. It is also stated that even remote code execution and privilege escalation can be performed. Is the up gradation is the only way to patch security hole or is there any remediation available for Docker’s older version.
