My computer has Avast Antivirus Version 7.0.1474 which failed to remove many detected threats. I plan on installing Bitdefender 9 internet security which has the USB immunize. Would it be compatible with my PC that runs on an XP system?
Any reviews on Bitdefender 9 internet security?
I think your problem can be easily resolved with a quick heal with latest update use this by uninstalling Avast antivirus. Once your problem solved there I recommend one of the most valuable products by Microsoft i.e Microsoft security essential , No need of product key only you need is time by time updating of its database. And this product comes free from Microsoft.
Thanks
