I want to know if there is any such application available on the internet which is written in Delphi and which helps in scanning 3D objects using a video camera?
I have heard of one such application though known as GRASP3D but I am not sure if its free to download or not.
Please tell me what are the free applications available for the Delphi laser scanner?
Any software application for delphi laser scanner?
GRASP 3D is still in development as a commercial product, for the time being they are providing a public release where the users can be involved in the development procedure
The 3D scanning program is free to download. The one you need to buy is the laser. If you already have the laser scanner, you can then just download the GRASP 3D Scanner Alpha 1.3 and use it with your laser. But if you still require another laser, they provide two types of low-cost lasers.
The first laser they offer is a focus-adjustable red line laser which generates a very thin line. It costs around $14.99. The second laser they offer is a bright green fixed focus laser which produces a high intensity thin line. It costs around $46.99.
Laser scanner
The GRASP 3D Scanner software is a 3D topographic scanner that allows you to scan objects in 3D using a video camera, a laser line, and some basic materials.
1....
