Any software related to thumbnails slideshow free on web site?
Hi to every one. I have developed a web site which uses thumbnail images mostly.
But I want to use images as a slideshow with out any CSS, HTML Coding or javaScripting for this.
Is there any tool or software which could convert images to thumbnails slideshow free easily?
Any solution please.
Best Answer by Hodge Trafton
Answered By 80 points N/A #137518
Greetings Kimghartwick,
I'm sorry but you can't change something about website without coding it.
You have to work both in html/css and use some other language as well.
If you don't like JavaScript how about jQuery?
Take a look at this website and see how its done.
It is pretty simple and easy check here
I hope this helps you,
Regards
Answered By 10 points N/A #137519
Hi. If you have enough knowledge of html, css and jquery language you can create your own thumbnails slideshow by coding it yourself. But there is also available software over the internet where you can use for your slideshow. You can check the following links, it may help you to finish your work.
  • http://visualslideshow.com/ – It is a free software that can help you create your slideshow easily with wonderful transition effects without making any codes. This software is easy to use and understand. You just need to drag & drop your photos, choose the effects, save then publish.
  • https://www.cincopa.com/media-platform/services/create-slideshow – This is also a free slideshow creator which is well-matched to any website. It is also easy to use. Just download the software, create your slideshow and embed the html to your website.
