Any software for the setup wwigo Symbian s600 2nd edition?
To All Techyv Users:
Hello Anjel,
WWigo has requires the following to work:
· Nokia series 60 v2.0 or 3.0. It should be Bluetooth enabled.
· Desktop should have Windows 2000 or XP SP2
Your PC should have either inbuilt Bluetooth or an external USB Bluetooth doodle. You should then turn on Bluetooth functionality on both devices and wwigo will work.
Hello Anjel,
First here is the list of Nokia phones compatible with wwigo:
6210 N, X5-01, C5, E5, E72, E63, E71, E73, E75, E52, E51 E66, E90, E55, E65 N73, N95, N96, N79, N86, N82, N85, N78, N81, N72, 6700 S, 5730, 6120, 6760, 5320, 5630, 6790, 6220, 6730, 6720, AND 6710 N.
WWIGO uses Bluetooth to connect the mobile and PC component and with the latest version it has Live upload with YouTube to easily share your video. WWIGO can also record videos from your mobile phone to your PC.
There was a known issue with IVT and Toshiba Bluetooth stack but in their latest version the bug was fixed.
Try installing WWIGO version 1.4 that has also WiFi support.
For the mobile component part go to this site on your mobile to download the application. Wap.mobimalt.com
Notifications
