Any software to use nokia c5-03 as a webcam?
Hi Olivia Matthews,
There are lot of apps available to convert your Nokia phone into Webcam and use it on Windows.
Some of them are :
Great and simple to use. Supports large no. of phone models. You can download it from here : http://mobiola.com
Compatible with Skype, Windows Live Messenger and other applications. You can download it from here :
Easy to use and recommended by many users. Download it from here :
In addition to using your Nokia handset as a webcam on your computer, you can also use any Android Smartphone handset. Most Smartphones nowadays have excellent built-in cameras which are sometimes better than the average webcam devices bought from the computer store. You can do this so you won’t have to buy for a separate web camera anymore. Here’s the procedure on how you can transform your ordinary Smartphone into one unique computer web camera:
