Any solution as to why I cannot record on CD?
I am trying to record/ burn my CD but I couldn't make this possible. This is the first time that I'm going to use my CD Burner. I am using a Windows XP.
If you have a compatible CD burner, you shouldn't need to do anything specially to get it working under Windows XP. If you're unable to record a CD, check to ensure that the feature is properly configured:
I don't have the "Recording" tab.
Where can I go to check if my CD-RW Drive is compatible? What are my other options?
If the CD-R drive or the CD-RW drive is not recognized as a recording drive by Windows XP, but the drive is recognized only as a CD-ROM, confirm that the CD-R drive or the CD-RW drive is compatible with Windows XP. For example, confirm that the drive is compatible with Windows XP if the recording tab does not appear.Â
This solution works for me. Thanks so much for helping a beginner like me!
