Any suggestion for Alcatel sim card Unlocker software?
I have to unlock my Alcatel mobile phone.
The model number is OT 356.
Anyone had any suggestion on where I can find any Alcatel sim card unlocker software?
Thanks in advance for your answer.
To unlock an Alcatel mobile phone, you first need an unlock code . You can get a free Alcatel unlock code either by contacting your Alcatel support. They will need your Alcatel phone’s IMEI number in exchange for the unlock code.
You can your phone’s IMEI number by entering *#06#. If you cannot get a free unlock code from the support, then you can try downloading some software to unlock your Alcatel phone.
Once you have your Alcatel unlock code, you can start unlocking your phone. These steps should work on almost all Alcatel mobile phones. Here are the steps:
How To Unlock Alcatel Phones
1. Power on the Alcatel mobile phone without the SIM Card in
2. Type: *#0000*CODE#
3. Finally, type: *#0001*CODE#
(Where CODE = your Alcatel unlock code)
Now you should have yourself a fully unlocked Alcatel mobile phone. You can use it on any other phone carrier now, enjoy.
How To Get An Unlock Code
Getting a free unlock code by requesting it from the carrier may not always work. Alternatively, I recommend trying to find your code by using an instant unlock site.
