Any suggestions for Internet erase utility?
Hi guys, I need some suggestions here. I'm looking for an Internet erase utility that can delete permanently algorithms and lists of visited sites, typed URL's and the like. A trial version would be OK so I could try it out first. I'm on Windows XP 64 bit. Thanks.
Best Answer by Keith J Harmon
Answered By 10 points N/A #149509
Hi Daniel Nicholass,
That means you are finding cache memory eraser software which will delete your cache memory. There are many software which you can download and install them for deleting cache memory. Personally I am using “Advance System Care” but there are many such as “CCleaner”. You can download both of them and try to understand which one is best for you.
Here the links:
https://advanced-systemcare.en.softonic.com/
http://www.piriform.com/ccleaner/download
Have a good day.
Answered By 10 points N/A #149510
Dear Daniel,
You can use Revo Uninstaller. It supports Windows XP x64 bit. It gives you 30 days free trial. It can do more than clearing the internet history and cookies. With it you can un-install programs and removing all the leftovers, clear the registry and remove Junk files.
As a browser cleaner it allows you to clear the history, delete internet temporary files, delete the cookies, delete download history and delete from history.
Revo uninstaller Revo uninstaller Module Revo Windows Cleaner
