Any tool that can convert .exe in mp3 online?
I have heard that there is a tool that can convert .exe in mp3 online, am wondering could this be a malware or such tools do exist.
Some help please.
Some help please.
Hello my friend, there is really a tool that can convert .exe to mp3.
But my advice to you is never accept a mp3 in .exe format it might cause a problem to your computer.
Here is a converter that will convert MP3 to exe:
Hope this help you.
.exe is executable file that is used to run a program and not to play music like files but there are converters that are being used for some specific purposes.
Smith Thompson
Aabel,
There are tools that can assist you in converting an .exe to a Mp3.
I have found a couple websites that offer free downloads they are listed below:
http://converter1.software.informer.com/download-converter-mp3-to-exe/
https://en.softonic.com/s/mp3-exe-converter-1.31
Once you have downloaded either software package, just load your Mp3 and the program will walk you through the process of the conversion.
Every solution suggested here is just fantastic. Rute Barga, the link you provided is excellent and I got a solution that does just what I wanted.
After visiting the link I also learned a few things that I did not know prior to this.
Now having downloaded this Software I am able to finish my task with much ease.
Many thanks to the techyv.com team and Rute Barga.
