Any Video Converter Free 3.3.9
The latest version Any Video Converter Free 3.3.9 is really an useful software. In the conversion of files will the resolution remain same as the original?
Hi Jessielucyy,
The resolution will not change any way after converting in to the different format. It allows people to effortlessly convert video files between every format. It has easy-to-use graphical interface, fast converting speed, and excellent video quality. It can convert almost all video formats including DivX, XviD, MOV, rm, rmvb, MPEG, VOB, DVD, WMV, AVI to MPEG-4 movie format for iPod/PSP or other portable video device, MP4 player or smart phone. It also supports any user defined video file formats as the output.
The new features of the version 3.3.9 is adds new output profile supporting Samsung Galaxy S III and refines the video conversion engine with faster speed and higher quality.
Yes, of course. The screen resolution or the screen size of the video will remain the same after the conversion. All video converters set the screen size to “default” or “automatic” when converting. But you can override this option if you want to change the screen size. The video converter offers different screen sizes for the video depending on the format of the output.
For example, converting the video to 3GP format [*.3gp] may have the following screen sizes: 128 x 96, 176 x 144, 352 x 288, 704 x 576, and 1408 x 1152. A DivX or Xvid video [*.avi] can use one of the following screen sizes: 176 x 144, 320 x 240, 352 x 288, 352 x 240, 640 x 480, 704 x 576, 720 x 480, and 720 x 576.
If you don’t like the size or the output screen size of the video, other video converters also allow you to enter your own screen size. If you do this, make sure the custom screen size you’ll use is in proportion and will not stretch or shrink the video in an awkward manner. Incorrect screen size affects the image of the video.
