Any way to create two terminal emulator Ubuntu with the script
Hello, I have two scripts I need to run up when I started up my Ubuntu machine.
Is there any way to create two terminal emulator Ubuntu with the script?
Best Answer by Tonya David
Answered By 0 points N/A #178692
It is very much possible to open two emulators, Same time on your Ubuntu OS machine. There are quite a few feature full emulators available on the internet, Here is the few Terminal Emulators Terminator – Its good if you want to see all the process at the same time.
Best in class, Guake – Its a less configurable, Have some advanced features, Now I am sending a link where you can get more information and how to download
Answered By 0 points N/A #178693
you can use Init scripts which are the scripts that are in /etc/init.d. All the scripts in the init script will run at the boot up sequence. During boot, they are not called directly, but through a structure of symbolic links which manage the services which are to be started in a particular runlevel. The scripts which are symlinked from /etc/rcS.d are executed first. Then the scripts in /etc/rcN.d/ are executed, with N being the chosen runlevel (default 2).
The LSB specifies some scripts that are used for displaying the output of the initscripts. For more information on LSb look into /lib/lsb/init-functions in the Ubuntu forum.
Alternatively, you could follow the instructions given below
To install your own script, copy it to /etc/init.d, and make it executable, run the commands below in the terminal
    sudo cp myscript /etc/init.d
    sudo chmod +x /etc/init.d/myscript
To make the script run with the start argument at the end of the start sequence, and run with the stop argument at the beginning of the shutdown sequence:
    sudo update-rc.d myscript defaults 98 02
98 and 02 are the start and stop sequence which decide how early and late a service is started and killed.
These numbers lies between 00 and 99.
