Any Websites and Links for Fonts Remove Use vbs?
Good day to all! Do some of you know where to find websites or some links that can have fonts remove use vbs or uninstalling the fonts using vbs?
Hi Adam,
I have read your problem and get some prospects. I made a brief research with it and have a solution. I've also searched Google for a wider solutions. You can check the VBScript code in this Link :
and try if it works in you.
Hope it have resolved your problem.
Thanks and more powers.
You can resolve your problem by recommended software “Font Leader”. It has two features:
1. Menu extension:
Using this feature, you can install and uninstall fonts. Just right click on font file to uninstall/install.
2. Group leader in system tray:
You can create your own font groups using this feature. Just click on the program icon in the system tray area.
I hope this is very useful to you. Download VBS software from the following website.
