Anybody help me to choose best journal software Mac?
I want help choosing best yet simple journal software for mac OS, can anybody help me with this?
Any kind of help would be appreciated.
Hi Meegan Williams
I would suggest you two software's to elegantly maintain your journal.
1. Memoires: Considered a very easy to use diary software
2. Diary: It is an elegant and simple application to maintain your journal and is available on the Mac App Store:
I hope you would like both of them.
Good Luck!!
I recommend two of best journal software for your Mac.Â
They’re easy to use and to maintain.Â
I haven’t had any problem with them yet and they really serve their purpose right, which are journaling events in your life.
MacJournal It doesn’t have the interface of a diary but it contains a lot of features that you won’t find in other software which makes it unique. You can export your journals to PDF files, you can draw and created doodles in your entries and can print it if you want.Â
This is just an enjoyable journal and easiest diary software so far.
Day One this is a lot cheaper than Memories. The fact that it also has a version for iPhone and iPad makes it more interesting. If you have one existing in your Mac device you can easily sync the system together.Â
