Anybody please help about Background Remover 3.2 software
Juan M Flora 90 points N/APosted on - 03/30/2015
Can Background Remover 3.2 software work with Adobe Photoshop? Is there multi language interfaces? What are those?
Can I get merging facility between layers by using Background Remover 3.2 software? What I do exactly by using that? Are any additional features available in Background Remover 3.2 software? Is there any uninstalled software procedure?
Yes, Background Remover 3.2 can work with Adobe Photoshop.
While installing, you get an option to select the language where you would see multiple options like English, German , French, Chinese, and few more.
Using this software, you may not do merging but there are other few ways to do that. For more information on how to merge the layers in photoshop, you may use the below link:
There is no uninstalled software procedure.
For information on Background Remover 3.2, please use below link:
1....
