I recently purchase Dell XPS 17 with Windows 7 pre-installed and was wondering if someone knows how to add Mac OS X Snow Leopard theme to Windows 7, so my Windows 7 interface will look like Mac?
Provide me the link of mac theme for dell windows, if you know any.
Any kind of help will be appreciated.
Anybody provide me Mac theme for dell Windows 7?
Almost everybody wants to see his/her desktop excellent.
Ok, I'm giving you a link. Just go to the link and download the theme. Your desktop screen must look better than before.
After downloading install it and enjoy. But one thing is very important.
You have to know how to customize the theme to make it more excellent.
I think it will help you.
Hathy
Hello Eliza,
The theme will be downloaded to your system. After running the application; right click on your desktop, choose personalize. Under theme you will see Snow Leopard Theme.
Double click on it and your current theme will change to Mac OS X Snow Leopard theme.
Alfaro.
Hello Eliza Dunley,
There are a lot of theme packs that you can use to transform your Windows to look like Mac OS. I am going to suggest you one that I have personally used and liked.
The name of the application is Rainmeter and you can download it from: www.rainmeter.net/cms/
This application allows you to install themes, docks, widgets to your system that will completely transform it.
Here is a link to Mac OS X Snow Leopard theme for rainmeter.
I have attached a screenshot of what your desktop should look like after you have installed rainmeter and applied the theme correctly. You can find many themes, docks, widgets etc for Rainmeter on this website: www.deviantart.com
