Anybody tell me how to m4v remove DRM Linux?
I have Linux Kernel 3.5.2 and was wondering if someone knows how to remove DRM protection from m4v and other popular file formats? Any kind of help regarding this would be appreciated.
Hi,Â
I think that I have found a solution to this problem that you have. I found a website which contains a lot of topics for your problem, and how to solve it of course. Look up on this site,  (it is kind of long, but 100% safe and works 100%)
Has all the download links, and also manuals on how to remove the DRM protection.
regards,Â
M4V is a multimedia DRM-protected video container format designed specifically for Apple products like iPhone, iPod, and iTunes store. Because m4v is totally linked with Apple Inc. it is more likely that your m4v file will be protected by copyright which is Apple’s FairPlay DRM copyright protection. To remove the DRM protection from the video, you can use a video converter called M4VGear.
It is designed to remove DRM protection from iTunes videos and convert them into unprotected MP4 video format with 100 percent lossless quality. For Windows users, download it from M4VGear For Windows Trial. It supports Windows XP, Windows Vista, Windows 7, Windows 8, and Windows 10 both 32-bit and 64-bit. For Mac, download it from M4VGear For Mac Trial.
It supports OS X 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, and 10.11 El Capitan. The trial version allows you to convert only one minute of the video. You need to purchase the full version from M4VGear Purchase Full Version for $44.95 to convert the entire video.
