Anyconnect client for Symbian OS tunneling
I have an 8 GB Nokia E6 that has 680 MHz ARM 11 CPU and Symbian Anna OS.Â
Will the Anyconnect client for Symbian OS be able to tunnel using Cisco SSL Tunneling Protocol.Â
Please help. Thank you.
Hello Harris Martin,
I read about your question and think can help you, what you want to do is possible, I think.Â
All the information you need can be found on the following pages.Â
1. Cisco com en US docs security vpn_client/anyconnect/anyconnect24/release/notes/rn-ac2.4-symbian.pdf
2. Cisco com en US prod collateral vpndevc/ps5743/ps5699/ps10884/datasheet_c78-678242.html
3. Cisco com en US docs security vpn_client/anyconnect/anyconnect24/symbian-user/guide/symbian-anyconnect-ug-24.htmlÂ
I hope that the information will help you, good luck.
Regards!
Nathan H Underwood
