AnyDVD HD 6.6.4.2 Failed to read DVD!
When I insert my DVD to AnyDVD HD it gives this error, it was working fine earlier. Please help
AnyDVD HD 6.6.4.2
WARNING!
Failed to read DVD!
This could have several reasons.
AnyDVD HD 6.6.4.2
WARNING!
Failed to read DVD!
The workarounds are on the error message itself. Check which region were your movies are and then set the AnyDVD region on the same region. Go to the links listed from the error and try to find the firmware needed.
And also, this error often occurs when you try to play a unprotected media. If this is the case, disable the AnyDVD and play the media file.
It might be that the DVD media is dirty or it might get damaged as well. There is hundred percent change that the reason might be any one of the two. You need to understand that DVD media needs to be in perfect condition. Try to find out which one out of the two above is the cause of problem in your case. I hope this is the solution as you just need to replace the DVD.
Waters Magner
