Anyone could help me on how to install yosemite 10.10.1
I need help on installing Yosemite 10.10.1. I want an easy step-by-step-instructions as I am not really an advanced user. Thanks in advance.
Here are the basic requirements for Yosemite 10.10.1
1.     Intel Processors or AMD
2.     From Windows XP up to Windows 10 all are compatible.
3.     Minimum of 2GB RAM
4.     8GB Hard Disk Space.
Here are the steps in installing Yosemite 10.10.1
1.   You need to download first Hackintosh OS X10.10.1 Yosemite (Build: 14B25).ISO file. It’s a little big file so make it sure you have good internet connection.
2.   Then mount the Hackintosh ISO image file.
3.   You need to install R-Drive after this.
4.   Then you need to expand the image 10.10.1.usb.arc to any bootable USB drive or DVD disc for installation.
5.   While installing the software, create a partition and load the flash to make MAC OS X installation.
6.   Select a Boot Menu section on the installed Mac OS X Yosemite.
7.   Install the boot loader and other files.
Please make it sure that before performing any tasks like this you made a back-up for files to prevent loses and problems if any system crash will happen.
