lark yency
20 points
Posted on - 08/20/2012
When I first installed Windows 7, I also enabled 3d acceleration. Today I upgraded my PC with ATI Radeon HD 5570 and whenever I try to launch Sniper Elite V2 game, it crashed. I researched a little and came to know that 3d acceleration of Windows 7 is conflicting with ATI drivers. Does anyone know how to disable 3d acceleration? Any kind of help would be appreciated.
Anyone help me to disable win7 3d setting?
Follow the instruction to disable Windows 7 3d settings:
Click Start
Go to Control Panel
Double Click Personalization and select Display Settings
Click Advanced Settings
Click Change Setting on the Troubleshooting tab
Move to the Hardware Acceleration Slider to None
Click Apply and OK
Click OK again
Restart Windows
I think your work has been done.
Thanks
Hathy
Hi? Please follow these steps to disable Windows 7 3d setting. Just work step by step:
Choose Start > Control Panel> Click Double on Personalization and select Display Settings> Click Advanced Settings> Click on the Change Settings of Troubleshooting tab> Move the Hardware Acceleration slider to none > Click Apply and then click OK to accept the new setting and close the dialogue box> Click OK to close the Display Properties dialogue box> Restart Windows. This worked for me in Windows7. Hope it will help you.
