Anyone help me in finding Java Simple Games Source
Hi Experts
I am learning Java Language. I want to have some simple Java Games so that I could try to make something similar to them. Can anyone help me in finding Java Simple Games Source ?
Hi Experts
Hello there,
I understand you are looking for basic source for "Java Games" which are very simple and doesn't need any high class coding.Here are a couple of links you can refer to for source codes of games like Pacman, Tic-Tac-Toe :
1.) http://www.java-gaming.org/index.php?topic=26759.0  – This link will provide you many source codes, there are total 10 source code available on this site for games like Tetris, Minesweeper, Tron etc. The links for source codes are either of pastebin or that of mediafire. These source codes will be of particular interest to you as they are very simple games and the codes are very basic, meant for the beginners.
2.) http://forum.codecall.net/topic/43209-java-source-code-tic-tac-toe-game/ – The complete source code of Tic-Tac-Toe is available here. There are 3 different source codes for the same game with slight modifications in each version.
I hope this will help you out!
