Anyone help me to search Samsung cell unlock code.
Recently my friend purchased Samsung cell from UK and had to move to Egypt for work.
After moving to Egypt, his cell is asking for country code.
He asked me about code to unlock but I don’t have slightest idea to begin with, what is it about?
Can anybody help me to search Samsung cell unlock code?
Best Answer by Recorter Qyut
Answered By 5 points N/A #134208
Samsung cell if not having Android, means its just got a normal Samsung's own software then try one of the following codes,
When it prompts for country lock code just type one of these codes, if not working try others,
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
If your phone still showing locked status then go to following link,
Search your phone model from the drop down menu, your country for which you want to unlock and enter IMEI number of your phone and you will have your phone unlocked.
Answered By 5 points N/A #134209
To unlock your phone, you can go to the Samsung phone dealers in the country and they can be able to unlock it for you.
However, I have combined for you easy Ways to unlock your phone.
  1. You can visit this site You will select your phone and search for the unlock code after inserting the required information. Then you will receive an 8 digit Samsung Unlock code (Network code) and easy to follow instructions, your Samsung phone will be unlocked within 2 minutes. You will then be able to make use of your unlocked Samsung Smartphone and use the SIM card of your choice. Once your Unlock Samsung by Unlock Code, it is permanently unlocked, even after you update your firmware. The advantages of using this site is that you can Easily switch SIM cards between GSM Carriers using the same device, you will get the Samsung Unlock code via Email. It is relatively cheap.
  1. You can also check out this sites;
https://www.fastgsm.com/en/page/how-to-unlock-samsung-via-imei-s5230-star-s5620-monte-galaxy-tab-s3370
http://www.unlock-genius.com/
Answered By 0 points N/A #134210
Unlock code is used to unlock mobile phones from network lock.
What's your mobile phone model and current network provider?
You can get unlock codes for your Samsung cell in this site Classicunlocking.
To get code here specify the following information.
  • Your mobile phone manufacturer name and model number
  • The name of the network or service provider your mobile phone is currently locked to
  • The IMEI number of your mobile phone
