Anyone help me to synchronize files with SkyDrive?
Recently I downloaded SkyDrive from Microsoft and faced a weird issue. I personally synchronized files in a SkyDrive folder with the web, but when I opened the web account, none of them were synchronized. Does anybody know why it happened? May be I followed the wrong process? Please tell me how to synchronize files with web?
Answered By 0 points N/A #134265
Hello Caecil,
When you are synchronizing files with SkyDrive, make sure that you are running the program before pacing files in the SkyDrive folder.
Here are the steps:
1. Place the file that you want to sync into the SkyDrive folder. Again, make sure that you have the SkyDrive program running, or it will be less effective.
2. You can see a green icon with a check. This means that you have successfully synchronized the file to SkyDrive. If it has a blue icon that means it is still processing or syncing.
3. If you want to sync files from your web account, you can also do the above actions from this.
If you are still having problems, please feel free to ask for help here.
Reaiu Hathy
