Anyone here familiar with Micromax phone models?
I'm looking to buy a cheap new GSM 900 Micromax QWERTY phone. I just need it as a spare phone to make calls and receive SMS messages. Anyone here familiar with Micromax phone models?
Thanks in advance.
Best Answer by Devorett Carlson
Answered By 0 points N/A #170832
Hello, Parkes Henry!
Do you want to buy a Micromax QWERTY phone for local use? I suggest that you buy any of the Q series of Micromax. Preferably the models Q36 and Q7. Q36 performance is very good and looks stylish. It has a user-friendly menu. Here is an image of this phone. Hope it will be one of your final options.
Micromax
Have a good day.
Answered By 0 points N/A #170833
Hello Parkers,
As per your requirement I think you can use “Micromax Qwerty & Touch Dual Sim Phone – Q34”. This phone has a rich features which can easily fulfill your requirements. Not only that, this model is very stylish and easy to use. Moreover it compares cheap in price with the same of other models. Here is a view of this phone:
