Anyone here knows Zorro Macsk?
Zorro Macsk was designed and developed by TMDtouch. It is a touch-screen device for imac. And the question is, is it compatible on windows too?
Zorro Macsk allows you to experience full touch functionality to your iMac buy connecting the USB cable at the back of your iMac. It is not possible to be use in windows platform because Zorro Macsk is specifically designed for iMac. Its name was a combination from “mask” and “mac”.
Good day Karrie,
What a nice question there buddy, but before I answer that question let me describe what Zorro Macsk is;
Zorro Macsk is an accessory for Imac developed by TMDtouch from Shenzen, China that makes your Imac touchscreen. amazing isn't it? now back to your question, is it compatible on windows? the answer will be it depends on what OS you will be using, Windows 8 and 7 will be able to run this but not that smooth and a bit laggy and on the other side I doubt in Windows Xp and Vista because it is already outdated.
Take care!
