Anytime USB Charge Download Link?
Hi John Shepich,
The best link that can be used to
access the download of the said software utility is: www.rocketdownload.com. It is
possible to charge external devices using the USB charge connector. The charge
connector acts as a link to the external device. The port is different from the
standard port by way of the power plug icon.
Hello there !!
So you want to know the uses, specification, characteristics of the usb charger recommended by your friend. So lt me tell you that the usb charger utility is awesome thing to use with and when talking about its characteristics, specification then it is uncomparable. So here i am giving you some detail about anytime usb charge utility.
Description:
File: FTS_AnytimeUSBChargeUtility_10010005_1068393.zip
version: 1.00.10.005
date: 13.01.2012
manufacturer: Fujitsu
Operating systems:
All windows 7 versions.
